Sonos bridge and more generally device_description.xml file
Can someone having a Sonos bridge check if the Sonos bridge is listed as a zone player when using the URL http://:1400/status/topology with the IP of one real Sonos zone.
If it is, is there a way to identify it ?
@guessed: note that in this report, we have the Coordinator and Group columns that could hep us for the group stuff.
Hi @lolodomo
Yes it is, the Sonos Bridge is listed as a zone player.
Althought it does not have all the options under :1400/status/
[code]Options
upnp
zl
topology
controllers
enetports
proc/net/arp
proc/interrupts
proc/net/snmp
jffs/localsettings.txt
tmp/upgrade.log
jffs/upgrade_tmp_prev.log
jffs/upgrade.log
jffs/upgrade_prev.log
jffs/lockup.anacapa.trace
jffs/lockup.dmesg
VERSION
etc/resolv.conf
proc/ath_rincon/status
tmp/wifi_card_mac_addr
opt/log/anacapa.trace
proc/ath_rincon/fullstatus
proc/ath_rincon/phyerr
proc/ath_rincon/nf
opt/log/hostapd.log
opt/log/netstartd.log
dmesg
ifconfig
route
ps
uptime
date
showstp
mount
df
showmacs
syssettings
securesettings[/code]
Do you want to see the device description?
http://x.x.x.x:1400/xml/device_description.xml
In the XML file result of http://x.x.x.x:1400/xml/device_description.xml, I discovered one interesting thing: a relative link to the player icon. For example, in my case, I have “/img/icon-ZP120.png”. To get the image, then you have to use this URL http://x.x.x.x:1400/img/icon-ZP120.png
That could be fun to display this image rather than the generic Sonos icon for the Vera device. Unfortunately, I think that the URL has to be fixed in the JSON file…
In this XML file, we have the tag “modelNumber”. What value do you get for the Sonos bridge ?
Could you check whether service urn:schemas-upnp-org:service:AudioIn:1 is listed in serviceList for a Play:3 ?
[quote=“lolodomo, post:4, topic:173694”]In the XML file result of http://x.x.x.x:1400/xml/device_description.xml, I discovered one interesting thing: a relative link to the player icon. For example, in my case, I have “/img/icon-ZP120.png”. To get the image, then you have to use this URL http://x.x.x.x:1400/img/icon-ZP120.png
That could be fun to display this image rather than the generic Sonos icon for the Vera device. Unfortunately, I think that the URL has to be fixed in the JSON file…[/quote]
I love that idea !! - You can always add the icons to the install package and then people can install them via the UI.
I can’t seem to see ‘modelnumber’ in the Bridge XML.?
Sorry, I only have a Play 5, Connect, Conet:AMP, Bridge & CR200 Controller.
Sorry, I only have a Play 5, Connect, Conet:AMP, Bridge & CR200 Controller.[/quote]
This is everything I have for a play 3, am I in the right spot?
[code]
urn:micasaverde-com:serviceId:Sonos1
*SetURIToPlay (URIToPlay)
*PlayURI (URIToPlay)
*Say (Text,Language,Volume)
*SavePlaybackContext
*RestorePlaybackContext
urn:upnp-org:serviceId:AVTransport
*SetAVTransportURI (InstanceID,CurrentURI,CurrentURIMetaData)
*AddURIToQueue (InstanceID,EnqueuedURI,EnqueuedURIMetaData,DesiredFirstTrackNumberEnqueued,EnqueueAsNext)
AddMultipleURIsToQueue (InstanceID,UpdateID,NumberOfURIs,EnqueuedURIs,EnqueuedURIsMetaData,ContainerURI,ContainerMetaData,DesiredFirstTrackNumberEnqueued,EnqueueAsNext)
*ReorderTracksInQueue (InstanceID,StartingIndex,NumberOfTracks,InsertBefore,UpdateID)
*RemoveTrackFromQueue (InstanceID,ObjectID,UpdateID)
*RemoveTrackRangeFromQueue (InstanceID,UpdateID,StartingIndex,NumberOfTracks)
*RemoveAllTracksFromQueue (InstanceID)
*SaveQueue (InstanceID,Title,ObjectID)
*BackupQueue (InstanceID)
GetMediaInfo (InstanceID)
GetTransportInfo (InstanceID)
GetPositionInfo (InstanceID)
GetDeviceCapabilities (InstanceID)
GetTransportSettings (InstanceID)
GetCrossfadeMode (InstanceID)
*Stop (InstanceID)
*Play (InstanceID,Speed)
*Pause (InstanceID)
*Seek (InstanceID,Unit,Target)
*Next (InstanceID)
*NextProgrammedRadioTracks (InstanceID)
*Previous (InstanceID)
*NextSection (InstanceID)
*PreviousSection (InstanceID)
*SetPlayMode (InstanceID,NewPlayMode)
*SetCrossfadeMode (InstanceID,CrossfadeMode)
*NotifyDeletedURI (InstanceID,DeletedURI)
GetCurrentTransportActions (InstanceID)
*BecomeCoordinatorOfStandaloneGroup (InstanceID)
*BecomeGroupCoordinator (InstanceID,CurrentCoordinator,CurrentGroupID,OtherMembers,TransportSettings,CurrentURI,CurrentURIMetaData,SleepTimerState,AlarmState,StreamRestartState,CurrentQueueTrackList)
*BecomeGroupCoordinatorAndSource (InstanceID,CurrentCoordinator,CurrentGroupID,OtherMembers,CurrentURI,CurrentURIMetaData,SleepTimerState,AlarmState,StreamRestartState,CurrentAVTTrackList,CurrentQueueTrackList,CurrentSourceState,ResumePlayback)
*ChangeCoordinator (InstanceID,CurrentCoordinator,NewCoordinator,NewTransportSettings)
*ChangeTransportSettings (InstanceID,NewTransportSettings,CurrentAVTransportURI)
*ConfigureSleepTimer (InstanceID,NewSleepTimerDuration)
GetRemainingSleepTimerDuration (InstanceID)
*RunAlarm (InstanceID,AlarmID,LoggedStartTime,Duration,ProgramURI,ProgramMetaData,PlayMode,Volume,IncludeLinkedZones)
*StartAutoplay (InstanceID,ProgramURI,ProgramMetaData,Volume,IncludeLinkedZones,ResetVolumeAfter)
GetRunningAlarmProperties (InstanceID)
*SnoozeAlarm (InstanceID,Duration)
urn:upnp-org:serviceId:RenderingControl
GetMute (InstanceID,Channel)
*SetMute (InstanceID,Channel,DesiredMute)
*ResetBasicEQ (InstanceID)
*ResetExtEQ (InstanceID,EQType)
GetVolume (InstanceID,Channel)
*SetVolume (InstanceID,Channel,DesiredVolume)
*SetRelativeVolume (InstanceID,Channel,Adjustment)
GetVolumeDB (InstanceID,Channel)
*SetVolumeDB (InstanceID,Channel,DesiredVolume)
GetVolumeDBRange (InstanceID,Channel)
GetBass (InstanceID)
*SetBass (InstanceID,DesiredBass)
GetTreble (InstanceID)
*SetTreble (InstanceID,DesiredTreble)
GetEQ (InstanceID,EQType)
*SetEQ (InstanceID,EQType,DesiredValue)
GetLoudness (InstanceID,Channel)
*SetLoudness (InstanceID,Channel,DesiredLoudness)
GetSupportsOutputFixed (InstanceID)
GetOutputFixed (InstanceID)
*SetOutputFixed (InstanceID,DesiredFixed)
GetHeadphoneConnected (InstanceID)
*RampToVolume (InstanceID,Channel,RampType,DesiredVolume,ResetVolumeAfter,ProgramURI)
*RestoreVolumePriorToRamp (InstanceID,Channel)
*SetChannelMap (InstanceID,ChannelMap)
urn:micasaverde-com:serviceId:Volume1
*Down
*Mute
*Up
urn:micasaverde-com:serviceId:MediaNavigation1
ChapterDown
ChapterUp
DiskDown
DiskUp
FastForward
*Pause
*Play
QuickSkip
Rewind
*SkipDown
*SkipUp
Slow
*Stop
urn:micasaverde-com:serviceId:HaDevice1
Reconfigure
StressTest
Remove
*Poll
*ToggleState
SetPollFrequency (PollingEnabled,PollMinDelay)
urn:sonos-com:serviceId:Sonos1
urn:schemas-micasaverde-com:device:avmisc:1
urn:upnp-org:serviceId:DeviceProperties
urn:upnp-org:serviceId:ContentDirectory[/code]
This is everything I have for a play 3, am I in the right spot?[/quote]
No. We are taliling about the XML file result of this command: http://x.x.x.x:1400/xml/device_description.xml (replacing x.x.x.x by the IP address of your Sonos)
[quote=“parkerc, post:6, topic:173694”][quote=“lolodomo, post:4, topic:173694”]In the XML file result of http://x.x.x.x:1400/xml/device_description.xml, I discovered one interesting thing: a relative link to the player icon. For example, in my case, I have “/img/icon-ZP120.png”. To get the image, then you have to use this URL http://x.x.x.x:1400/img/icon-ZP120.png
I love that idea !! - You can always add the icons to the install package and then people can install them via the UI.[/quote]
The idea would be to join the different icons and then to use a capability of the json UI file to select the good icon depending on a value that will be set by the plugin depending on the model number.
I have already discovered 2 icons:
Can you check the icon file name for your different Sonos with the corresponding tag “modelNumber” please ?
As the URL depends on the IP address of the Sonos unit, unfortunately I don’t think we can get the icon directly from the Sonos. We will need to store the different icons in the Vera.
http://wiki.micasaverde.com/index.php/Luup_plugin_icons
[quote="lolodomo, post:4, topic:173694"]In this XML file, we have the tag "modelNumber". What value do you get for the Sonos bridge ?[/quote]
Can you provide the XML file for the bridge ?
The number of icons is limited to 5. Hopefully, that is enough for Play:3, Play:5, Connect and Connect:Amp.
My idea is to add these files:
Sonos.png the default Sonos icon
Sonos_0.png for Play:3
Sonos_1.png for Play:5
Sonos_2.png for Connect
Sonos_3.png for Connect:Amp
One variable will be created and set to 0 or 1 or 2 or 3 depending on the model found in the XML file. Then the icon on the Vera device will be automatically adjusted.
I try that later today.
@lolodomo
Does this help
Play5 = /img/icon-S5.png
Bridge = /img/icon-ZB100.png
Taken from - http://x.x.x.x:1400/xml/device_description.xml
[quote=“lolodomo, post:10, topic:173694”]I don’t think we can get the icon directly from the Sonos. We will need to store the different icons in the Vera.
[url=http://wiki.micasaverde.com/index.php/Luup_plugin_icons]http://wiki.micasaverde.com/index.php/Luup_plugin_icons[/url][/quote]
As this returns the icon of the Sonos, ([url=http://192.168.x.x:1400/img/icon-ZB100.png]http://192.168.x.x:1400/img/icon-ZB100.png[/url]) can the .json dynamically look to that address ? Can the flash icon url address be calculated by a variable stored in the UI of the device e.g. the Sonos plugin also stores the /img/icon-xxxx.png location?
Hello,
I would dare to suggest Play 3 follows the same precedence… I have added the two icons for the bridge and Play 5.
<modelNumber>S5</modelNumber>
<url>/img/icon-S5.png</url>
[quote=“Brientim, post:14, topic:173694”]I would dare to suggest Play 3 follows the same precedence… I have added the two icons for the bridge and Play 5.
<modelNumber>S5</modelNumber> <url>/img/icon-S5.png</url> [/quote]
As S5 was the original name of that unit, before they changed it to Play5, my money is on the Play3 being either /icon-p3.png or /icon-play3.png. :wink: - place your bets…
[quote=“parkerc, post:15, topic:173694”][quote=“Brientim, post:14, topic:173694”]I would dare to suggest Play 3 follows the same precedence… I have added the two icons for the bridge and Play 5.
As S5 was the original name of that unit, before they changed it to Play5, my money is on the Play3 being either /icon-p3.png or /icon-play3.png. :wink: - place your bets…[/quote]
If I was a gambling man, I’d put my money on /img/icon-S3.png. ::slight_smile:
I just did a google search and found details contained here Sonos and MC17
<modelNumber>S3</modelNumber> <url>/img/icon-S3.png</url>
Damn !! ;D.
Strangely, I cannot get icon-S3.png while icon-S5.png (and others) is working. Can someone provide the icon ?
Now with the last plugin files, you should get the right icon for Play:5, Connect and Connect:Amp.
Still missing: Play:3. My Sonos (a Connect:Amp) does not provide icon-S3.png while it provides the 3 others.
I have not managed the Bridge for the icon, there is no need to create a Vera device for the bridge. If you do it, you will get the Sonos icon. But for the bridge, I now know that ZB100 is the modelNumber and so I have a mean to identify it in the network topology.
