@rigpapa I have Azure TTS working in Sonos 2.0 Many thanks!
I live in Holland and there is only 1 standard voice in my language = Dutch, female. But the lady speaks a bit too fast…
I found some other neural voices on their website (3 in Dutch) and they sound much better. But I can’t get them to work in the Sonos plugin. I choose for “user supplied/custom value” and used the abbreviations on the Azure website like “nl-NL-ColetteNeural”
But I hear nothing…
Is it possible to use neural voices ?
And if not, can I somehow change the speed ? I remember with ResponsiveVoice you could change the speed and tone of voices.
Neural voices are not available in all regions. You may need to change your region to get access to them.
See: Text-to-speech API reference (REST) - Speech service - Azure Cognitive Services | Microsoft Learn
Hi @rigpapa,
I know you said you didn’t want to chase neural voices because they were a moving target, but I thought I would let you know what I see.
I am on 2.0-hotfix20314.1625
I am set to a server (eastus) that supports neural, but there is no audio produced, and the log shows a received zero length response. I don’t believe it is an issue with my Azure service or settings, because “standard” voices work reliably with no issues.
Thanks again for everything,
