Hi there. I already saw here some question about sonoff integration.
I have Vera Plus, if i buy sonoff devices with zigbee protocol, do i need sonoff zigbee bridge or not. The products work directly with vera plus?
Thank you
Thank you
Continuing the discussion from Sonoff Zigbee:
At the moment, only EZLO hubs support sonoff devices. EZLO is a multiprotocol smart home gateway and does not need an additional Zigbee bridge.
The ZBmini works with Vera Plus!
It was a very strange installation as it refused to stabilize for several hours(continuously configuring), and then suddenly it started to work flawlessly.
Not so easy…
When trying to install my second MiniZB, I just cannot make it work. The first one continues to be flawless.
How can I best compare the two at a deeper and significant level?
I have compared variables and attributes as found in the Altui interface.
EDIT/SOLUTION:
EDIT 2
Tell us if this works!
Getting Zigbee devices to pair and work properly on the older Vera hubs was always black magic and hit and miss. Vera hubs really never worked that well at all with Zigbee devices.
Hopefully this will now change and improve with the newer generation of Ezlo hubs.
