If I would integrate Somfy blinds or somfy motors into Vera using the ZRTSI, what options would I get? I am trying to find screenshots of the UI but I cannot find anything.
My question specifically is about:
A) Lowering/Raising
B) Tilting
Will the UI give me those options or can I configure those options for blinds (not shades)?
the ZRTSI will just add a standard Z-Wave blinds device, as in the screenshot. You can program up to 16 of them (supports 16 channels). Mine don’t do tilting, so I’m not sure how you would do that …
@capjay can you tell me if you can user Vera to set the shades partially open? As opposed to either ‘open’ or ‘closed’ 100%? I/ looking at getting some shades but want the ability to set a scene to open the shades to 50% as opposed to 100% using the ZRTSI.
Somfy blinds typically go up and down or just tilt.
In either scenario you can program a scene to start going down and after x seconds you stop it.
Same with tilt.
scene delay of x seconds to run next task at the top of the scene. X is determined by you measuring how long the blinds take to come down and to what level you want them
You could create two scenes. One which goes all the way down which might take 12 seconds and one scene which presses the stop button after 6 seconds and your blinds are 50% down.
No need for complicated LUUP code here. Keep your life simple.
Excellent!
Yes, pretty simple doing it that way. Would be easy to have a couple scenes for a blind…set it 100% open, 75% open, 50% open, 100% closed.
Thanks for that. Looking at getting some Somfy powered blinds but hated the fact you couldn’t set them at a percentage height…but you have a decent work-around for this issue.
Update:
I ordered and installed my first couple of roller shades the other day with the Somfy motors. Used the ZRTSI II to connect with Vera Lite and now have the blinds automated to open at a certain time in the morning and close at sunset.
Also have the Amazon Echo integrated so I can speak the command “Alexa, close the living room shade”, and in a split second, the shade closes.
I did set up a scene with a delay also so I can close/open the shades 50%. Thanks again for that tip. Works great.
Pseudomizer, have you noticed lately that Alexa no longer understands “close”. I found a few weeks back that she now understands, “shut” (Alexa, shut family room blinds). Today however, I noticed she no longer understands “close” or “shut”.
I noticed the strangest thing today. I have several scenes for my blinds. Each blind has it’s own scene by name (family room blinds, bedroom blinds, etc) but I also have scenes for group like “house blinds” or “main blinds”.
By accident today I said “Alexa Open Main Blinds” instead of “Alexa Turn On Main Blinds”. To my surprise it worked. I then tried all the other blinds and groups with “Open” instead of “Turn On” and got the usual “I don’t know how to help you with that” response.
Can’t for the life of me figure out why she understands “Open” with one specific scene.
