Hi every one.
Just installed Vera Edge running U17 with an RFXtfx433E, Have just installed Beta 3 but just can’t get the blinds to run properly.
All that is happening Slats will open/close a couple of times (when blind fully down) then nothing after that no other buttons work, if the blind is in the fully up state, if Stop/My pressed blind goes to the My (favourite) state ie. blind fully down slats open, which is good but after that nothing else works again.
Up/Down produce a slight movement, then again nothing else works, after each crash I use the Somfy Telis remote to re-position the blinds, then some of the buttons work again for a couple button presses then crash again.
I use the Edge to control Lightwaverf/Siemens RF light switches/dimmers etc. no problems all work fine.
Anybody got any idea’s
;D Update
Problem solved, with a little help from my supplier and a few alterations to the L_RFXtrx.Lua code, and all is working fine, at least using the Vermate IOS App, fraid that the Vera UI plugin and Vera IOS App only partially work until they both crash and burn after more than one button press, guess they are just full of bugs as far as controlling lift & tilt Venetian blinds are concerned, as the Veramate (and AutHomationHD on android) both work perfectly using the same L_RFXtrx.Lua file!!!
