Has anyone looked at the Somfy Mylink [url=http://www.somfysystems.com/file.cfm/myLink_Spec_Sheet_Mar_2015.pdf?contentid=275864]http://www.somfysystems.com/file.cfm/myLink_Spec_Sheet_Mar_2015.pdf?contentid=275864[/url]? I’ve just had some motorised blinds installed and i’m looking at all the options and the Mylink seems like a good choice IF it can be hooked up to the Vera. It’s cheaper and smaller than URTSI / ZRTSI and plugs directly into a wall socket. I’ve read what i can and it seems to connect back to a central server somewhere so i’m wondering if it can be reverse engineered like the MyQ Gateway for garage doors.
Anyone got anything on this?
Thanks.
