Hi!
I’m new on the forum and I’ve been looking around for a plugin that would control the Somfy Connect module. while searching I found a plugin for the URTSI that could work… the plugin use serial port for communication, I Wonder if we could change the communication for IP to control the Somfy Connect
Another option is to use the RFXtrx433XL to control Somfy RTS devices. Note that Somfy IO-Homecontrol operates at 868MHz and cannot be controlled!
For more information on the RFXtrx plugin see USB RFXtrx Transceiver - Ezlo Community
thanks for the reply but I’m not using RTS devices, I’m using SDN RS485 motors. the Somfy Connect is a Universal Automation Interface (UAI) Plus that use IP to control the blinds. I was hoping that plugin could be used to control it.
