Some problems with Ivera
Hello, I installed Ivera free to do some tests in IVera2 but i found a number of problems that I put on the list:
  1. After setting up a scene in Vera and her later deleted, ivera does not update the deletion and the new scenes are not displayed.
  2. I do not see the cam in ivera Panasonic BL-C111 (correctly displayed on Vera)
  3. is not detected the Danfoss thermostat
Can someone help me with this?
  1. The device type of the Danfoss RA plus-w is ‘urn:schemas-micasaverde-com:device:GenericIO:1’. Maybe Ivera does not yet support this device type?
Hello,
The free version of iVera only reports 2 lights and 2 scenes. All extra devices on your Vera (thermostat, sensors, camera, door locks, window treatment) will only be accessible from the full version.
With respect to 1) there was an issue found which would not automatically update deleted scenes but doing a “Reset All Settings” (in your iPhone’s Settings application, find iVera, enable reset) should work around the problem for now.
Let me know if you have other questions.
