Some issues after UI7 upgrade
I am having a few issues after upgrading to UI7 that I hope someone can help me out with.
  1. I have an Aeon Labs DSC06106 smart energy switch which is just showing up as a normal on/off switch. How can I make it look like the Energy Module in the documentation? http://support.getvera.com/customer/portal/articles/1610917-devices-tab-pt-1-view-and-control-devices
  2. I also have a GE 45603 module which in UI5 showed up as a light switch. I had copied and modified the D_BinaryLight1.json & .xml files to be D_PowerOutlet.json & .xml with the only change being what PNG files they referenced. I just wanted a different picture since there is not actually a light plugged into the module. After the upgrade to UI7 the icon is the generic z-wave icon and if I select that device and try to view Settings/Advanced/Device Options I just see nothing. How can I either revert this back to a normal on/off switch or even better convert it to the Smart Switch icon on the same documentation page listed above. I haven’t tried just removing it and re-adding it as it’s used in a few scenes that I’d like to avoid recreating. But if that’s what it takes so be it.
Also, is there any documentation on the new Geofencing capabilities? I can’t find any details.
<<is there any documentation on the new Geofencing capabilities? I can’t find any details.>>
Add a scene from your mobile device. At least that is the only place I found for geofencing. It is not available on the web browser interface.
