Not sure how to remove the Netmon application. Does not work and just looking to get rid of it. But when I go to my plugin section for ALUTUI, there is no uninstall icon/link.
Are you sure you use the latest version, I use it daily and it does work quite fine.
I wrote it so I can help if you want , first thing is to update to latest version from github
If you want to uninstall it you have to delete the netmon device from your setup .
The files remains on Vera but that is usual behavior, if you want to delete the fils you have to remove them manually from Vera, that is all the files with NETMON in the name.
Sorry, this was a PICNIC issue.(Problem In Chair, Not In Computer). I was testing ping to my Windows PC. And as windows is vulnerable, the windows Ping ports are blocked via firewall, thus the failure. I added another host and works fine. Thanks for the quick reply. I will keep it and add more host.
Kyle
