I have just acquired a Vera Edge and I have tested Thingspeak a little bit. It is nice, but for power metering it looks like EmonCMS may be a better way to go.
Do you think it would be possible to allow monitoring to EmonCMS ? It actually looks to work in a similar fashion as Thingspeak so it does not look like it would be too difficult. In fact, a user has already made it work in the Vera, but as I am just starting out it may be better to enable it via AltUI ?
I’m trying to configure it now. First I have to figure out how to create an input and/or feed from the website. Looks cool, and more capable than thingspeak!
I am seeing an issue where once I’ve entered emoncms data for ONE variable in a device, that setting is carried over to EVERY variable of the device. I.e. if I set the info for “current temperature” for my thermostat, every variable for that thermostat will have “emoncms” checked and the data associated with “current temperature” displayed for every variable.
I seem to be able to manipulate things from the “variables to send” directly – so there’s a workaround.
I’m still trying to wrap my arms around emoncms: is the feed variable there just for visualization purposes? It looks like inputs (the data we send) should be purely determined by the node-ID and the name of the key. A feed seems to be a process to apply to a single input (like logging it).
I haven’t looked for documentation on emoncms which might explain it all – just reverse engineering at this point.
[quote=“tedp, post:10, topic:189647”]I seem to be able to manipulate things from the “variables to send” directly – so there’s a workaround.
I haven’t looked for documentation on emoncms which might explain it all – just reverse engineering at this point.[/quote]
