http://forum.micasaverde.com/index.php/topic,35347.0.html
Ideas folks?
My Sonos info:
Version: 6.0 (build 31322220)
My Vera info:
Vera Edge running 1.7.1707
Ideas folks?
My Sonos info:
My Vera info:
What server are you using for TTS? Have you tried a different one to see if that was the problem?
Currently using Microsoft which gives 5+ repetitions of a sentence. Google gives a sentence and a half. Or none randomly.
Sounds like its a TTS server issue if it changes. I’m using Mary without this issue. Not sure if your the only one having a microsoft issue or not.
Surely there are others using both Google and Microsoft TTS servers. If you look at the link in my first post, you’ll see that I’m not alone in having this problem.
Anyone?
Update: SAY has suddenly started working correctly. No software change. As near as I can tell the only thing that happened was the house lost power for 5 minutes or so, so everything rebooted. Very odd, but working now ;D
