Already using Chrome, but it does seem to be adblock related. Whitelisting in both adblockplus and ghostery allows the page to redirect. Given the likely high percentage of users with a blocker running it’d be good to at least take it into account with regard to putting useful links on the page. A screen grab of which is attached.
The Control link does bring up the Choose your controller screen. Which then does a Direct Connection. Which times out with the LUUP error.
But, for the sake of exhausting options, I tried using my Nexus 7, Samsung S6 and iPad 4 to connect. Both on the local WiFi network and via cellular data (turned off WiFi on them to force use of cell data). No change, same hang up at LUUP error. To really exhaust options I tried using IE9 on a different local machine. No dice, same error.
Weak power supply, well, I’m using the one they shipped with it. Which is listed as a WB-18D12FU 12v 1.5A. Nothing particularly special, it’s just your garden variety cheapie power supply. I suppose I could dig up another 12vdc suppy, but I’d prefer to let support chime in first. No sense blowing out the unit before they’ve had a chance to connect to it remotely. That and since the error is repeatable, and the unit stays connected, I’m less inclined to think it’s the power supply. PS problems tend to lead to things erroring out in different ways or locking up. It’s not often a power problem would be as cleanly repeatable.
I used the web page form to send an e-mail to support. I received what looks like a generic reply about two minutes later. It’s a Sunday so I wouldn’t expect a reply as the website lists M-F hours.
The box has gotten itself into some sort of state that leaves it unusable. This happening straight out of the box. Not a great way to get started.
I can, however, SSH into the box using ‘remote’ and the password generated for allowing remote connection. Any tips on what to “poke at” to get it past this LUUP issue?
Looking into the logs now. serproxy.log reports that it’s failing to download and find_self failed.
http://127.0.0.1:3480/data_request?id=lu_finddevice&devid=5000xxxx&devtype=urn:micasaverde-org:device:SerialPortRoot:1 to /tmp/serproxy.1-22816 with /usr/bin/curl -k -s -S --fail --connect-timeout 5 --max-time 5 -o "/tmp/serproxy.1-22816" "http://127.0.0.1:3480/data_request?id=lu_finddevice&devid=5000xxxx&devtype=urn:micasaverde-org:device:SerialPortRoot:1" Response 1792
I did a ‘tail -f LuaUPnP.log’ and it appear to be a continuous loop where it’s constantly running into this error:
2016-02-21 12:26:24 - LuaUPnP Terminated with Exit Code: 16
From one, to another, the log contains the same thing:
[code]---------------exited-------------
PID USER VSZ STAT COMMAND
1 root 1488 S /sbin/procd
2 root 0 SW [kthreadd]
3 root 0 SW [ksoftirqd/0]
4 root 0 SW [kworker/0:0]
5 root 0 SW< [kworker/0:0H]
6 root 0 SW [kworker/u4:0]
7 root 0 SW [migration/0]
8 root 0 SW [rcu_bh]
9 root 0 SW [rcu_sched]
10 root 0 SW [migration/1]
11 root 0 SW [ksoftirqd/1]
13 root 0 SW< [kworker/1:0H]
14 root 0 SW< [khelper]
93 root 0 SW< [writeback]
95 root 0 SW< [bioset]
97 root 0 SW< [kblockd]
105 root 0 SW [khubd]
120 root 0 SW [kworker/1:1]
138 root 0 SW [kworker/0:1]
142 root 0 SW [kswapd0]
143 root 0 SW [fsnotify_mark]
144 root 0 SW< [crypto]
233 root 0 SW< [krfcommd]
237 root 0 SW< [deferwq]
243 root 0 SW [jfsIO]
244 root 0 SW [jfsCommit]
245 root 0 SW [jfsCommit]
246 root 0 SW [jfsSync]
258 root 0 SW< [kworker/1:1H]
298 root 0 SWN [jffs2_gcd_mtd6]
412 root 892 S /sbin/ubusd
413 root 768 S /sbin/askfirst ttyS1 /bin/ash --login
1146 root 0 SW [kworker/u4:2]
1158 root 0 SW< [kworker/0:1H]
1286 root 0 SWN [jffs2_gcd_mtd10]
1516 root 1048 S /sbin/logd -S 16
1523 root 1132 S /usr/bin/btn -c /etc/config/button.ini -d
1524 root 1132 S /usr/bin/btn -c /etc/config/button.ini -d
1525 root 1132 S /usr/bin/btn -c /etc/config/button.ini -d
2432 root 0 SW [kworker/1:2]
2552 root 1584 S /sbin/netifd
2658 root 0 SW [RtmpCmdQTask]
2659 root 0 SW [RtmpWscTask]
2660 root 0 SW [RtmpMlmeTask]
2668 root 1648 S udhcpc -p /var/run/udhcpc-br-wan.pid -s /lib/netifd/dhcp.script -f -t 0 -i br-wan -C
2869 root 0 SW [RtmpCmdQTask]
2870 root 0 SW [RtmpWscTask]
2872 root 0 SW [RtmpMlmeTask]
3146 root 1652 S /usr/sbin/crond -f -c /etc/crontabs -l 5
3227 root 4180 S /usr/sbin/lighttpd -f /etc/lighttpd/lighttpd.conf
3232 root 1736 S /usr/sbin/dbus-daemon --system
3249 root 3360 S /usr/bin/bluetoothd -n -E
3289 root 0 SW< [kworker/u5:0]
3290 root 0 SW< [hci0]
3291 root 0 SW< [hci0]
3294 root 0 SW< [kworker/u5:2]
3446 root 1104 S /usr/sbin/ntpclient -i 600 -s -l -D -p 123 -h 0.openwrt.pool.ntp.org
3457 root 1648 S /usr/sbin/ntpd -n -p 0.openwrt.pool.ntp.org 1.openwrt.pool.ntp.org 2.openwrt.pool.ntp.org 3.openwrt.pool.ntp.org
3499 nobody 960 S /usr/sbin/dnsmasq -C /var/etc/dnsmasq.conf -k
3905 root 1652 S {Start_NetworkMo} /bin/sh /usr/bin/Start_NetworkMonitor.sh
3922 root 1816 S {cmh-ra-daemon.s} /bin/sh /usr/bin/cmh-ra-daemon.sh 127.0.0.1 80 vera-us-oem-relay41.mios.com 31023 06290873CB11FD257074476
3988 root 1232 S ssh -p 232 -T -y -i /etc/cmh-ra/keys/cmh-ra-key.priv -R 31023:127.0.0.1:80 cmh-ra@vera-us-oem-relay41.mios.com
5030 root 1796 S {SetupRemoteAcce} /bin/sh /usr/bin/SetupRemoteAccess.sh
5125 root 1796 S {SetupRemoteAcce} /bin/sh /usr/bin/SetupRemoteAccess.sh
5126 root 1212 S ssh -y -T -p 232 -i /etc/cmh/ra_key -R 24738:127.0.0.1:22 -R 25661:127.0.0.1:80 -R 11845:127.0.0.1:23 remoteassistance@vera
5127 root 768 S /usr/bin/charperiod
6227 root 7428 S /usr/bin/NetworkMonitor
6697 root 1148 S /usr/sbin/dropbear -F -P /var/run/dropbear.1.pid -p 22 -K 300
9637 root 1216 S /usr/sbin/dropbear -F -P /var/run/dropbear.1.pid -p 22 -K 300
10068 root 1656 S -ash
13220 root 1648 S tail -f LuaUPnP.log
15503 root 1660 S {Start_LuaUPnP.s} /bin/sh /usr/bin/Start_LuaUPnP.sh
15530 root 1648 S {Start_serproxy.} /bin/sh /usr/bin/Start_serproxy.sh
16160 root 1640 S sleep 58
17248 root 0 Z [sh]
17316 root 1640 S sleep 10
17462 root 1640 S sleep 5
17531 root 1648 R ps axf
---------------after sleep-------------
17248 root 0 Z [sh]
17534 root 1648 R ps axf
---------------after kill -9-------------
17248 root 0 Z [sh]
17536 root 1648 R ps axf
2016-02-21 12:27:10 - LuaUPnP Terminated with Exit Code: 16
[/code]
I tried using a pin held 10 seconds to factory reset. The unit did reboot after I held the pin for a 10 count and then released it. I don’t know how to tell if it succeeded or not. The end result, however, is unchanged as it’s still stuck in that loop.
