I’m not if this is by design and did not find any info about this.
I’ve noticed that I am unable to change the properties of a trigger. In the UI, it changes, but after change, UI does not reflect reality anymore.
If I have a Virtual Switch (VS) and creates a trigger in PLEG for when VS is true. It’s all fine and dandy. But if I choose to have that PLEG trigger reflect the status of a Multi Switch (MS) insted. The UI updates, but not the logics and the PLEG trigger will not act on MS changes.
This started with a GCal3 trigger that did not work. But one thing lead to another and I think I narrowed it down to this.
Does anyone know or can verify this is the case on your system as well?
My system is Vera Edge with 1.7.1707 and PLEG 7.47
