Last night I ran into an issue where my light switch didn’t have a neutral wire. Turns out I have whats called a switch loop. I was able to solve the problem with an Aeon Micro Switch. I can now manually control the light by using the light switch, or i can remotely control it using Vera. Here’s a diagram for others that might run into this problem.
Sometimes i find that although diagrams show the solution to a problem, it can be difficult for me to visualize how the diagram relates to my current setup. Showing the romex going into and out of the boxes is what helps me out because when i pull the switches out, i can easily translate what i’m looking at in the junction box with what i’m seeing in the diagram.
I swear every time i look at a diagram that shows line/neutral/ground, i have to draw the diagram myself and group the wires together into the corresponding romex wires going into and out of the junction box. I think its partially do to fear of screwing something up and potentially electrocuting myself or burning my house down.
Either way, diagrams are awesome, and i’ll be referring to yours tonight!
so if the wall switches are in an off position and you turn on the light via the Aeon Micro Switch, will a flip of the wall switch turn the light off? and visa-versa?
