[solved] no events
Hello
UI5
GCAL3 2.6
for 2 days I’m having a problem displaying events.
my calendar has events
and the module tells me:
“no more events today”
gc_NextEvent = Connecting …
gc_NextEventTime = Retry number 1
here is the get.log
thanks for the help
cordially
This is usually a network or connectivity error with google. From the logs - you are not getting an access token back from the google service. This could be a network issue or it could be a credentials issue or there could be a problem with your google account.
Unfortunately - I cannot help. You will just have to work through the problem. I’d suggest first rebooting routers, your vera and etc to clear any connection problems. Then re-enter your calendar id and credentials file. Also check your google console and see if your account has issues.
Bottom line - something has changed. If you remember doing anything then that would be a good place to start looking
thank you for the answer
I have nothing on the vera since a few weeks
this morning, where I updated the plugin to V2.6 (instead of v2.4 before)
I just tested with the GCal Test
calendar ID: <iframe src = "https://calendar.google.com/calendar/embed?src=rkhle303chdgeg5lpthj2jvsk4%40group.calendar.google.com%26ctz=America/Denver" style = "border: 0" width = " 800 "height =" 600 "frameborder =" 0 "scrolling =" no "> </ iframe> Credential File = GCal3Test.json
message :
calendarID is set
missing access_token
problem solved
[url=http://forum.micasaverde.com/index.php/topic,26692.msg418778.html#msg418778]http://forum.micasaverde.com/index.php/topic,26692.msg418778.html#msg418778[/url]
