I’ve started seeing this message in Vera UI7 for both my and my wife’s phones:
No Devices for this account, check network/credentials
My network is showing no obvious issues.
In the logs I see:
JobHandler_LuaUPnP::CreateDevice_LuaUPnP failed to load 17/D_IPhone.xml so device 17 is offline while waiting for download the file
which seems a little odd needing a file to use a device which has been in place for some months (with no noticeable issues so far)
There’s also an error I can’t find right now about failing to start imp something (sorry, rubbish report, I’ll get the error next time i can find it)
In the logs I see:
Any ideas?
Cheers
C[/quote]
this error is odd, sounds like a reinstall could eb needed but I d approach vera support for that initially
you can wait until the new version I published gets approved
or
you can open this url in your browser, http://:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=CreatePlugin&PluginNum=4686&Version=32912 and let it do its work , ignore all error messages displayed, let the VERA reload once or twice and check that you are running v 2.41 of the plugin
