I ditched the outdoor temperature plug-in and added the Weatherunderground plug-in to get additional weather data. For some reason, the humidity number is not shown in the icon, although I can select it and it appears ok. Can VeraMate be updated or is this a device/plug-in/Vera issue?
(Sorry I missed this post)
This sounds like the plugin is using a configuration that’s a bit non-standard. Do you have the link to the plugin?
By the way, these are the devices the app created.
Just got the update - thanks for adding the humidity! +1
