Vera > Usb 2 Serial > Serial to Ethernet > Visonic > ?
I tried using some dupoint cables/ jumper cables to match up the pins 3/5/6 from the ethernet cable (Solid Blue/White-Green/Green) but it doesn’t seem to be seen by vera…
This is the serial/usb device I am using - [url=http://pcscience.com/product.php?pid=20326&]http://pcscience.com/product.php?pid=20326&[/url]
Any ideas where I am going wrong? How do i debug this?
The panel connector on your diagram has TTL signals, not RS232. So you’ll need a TTL->USB or the Visonic RS232 breakout (and connect that to the RS232->USB).
Looking at my diagram… could someone give me an exact shopping list to connect them up… given that I have an ethernet cat5 run between both locations…?
So I bought that device… I plugged it in to PC link 8 pin connector…
I attached my ehternet cable to left port
I rebooted vera after clearing comms errors and setting the correct serial configuarion.
It failed
So I set forced standard mode and this created the Arm/Disarm/ArmHome device and I selected Z01 for the motion sensor installed and it created this device…
However, If i do anything with the set up it forces vera to reload…
I can’t arm or disarm…
I set up a scene to pass the pin number and run that… it cause vera to reload.
Am I supposed to be Powerlink mode?
Or Did I connect the add on card to the wrong place on the panel?
