[quote=“teonebello, post:1, topic:168276”]Hi all,
I bought two Everspring AN145 Lamp Holder but I’m not able to pair with VEra.
I put the Vera in “adding Device”, I put the lamp very close to the Vera. The z-wave led is blinking, and when I click the button in the VEra the led blink faster and then it remain on.
But I don’t see the device in the GUI.
Could someone help me?
Thank you!!!
Matteo[/quote]
If you screw a lamp into the AN145, and plug it into the outlet, and then look at the led on the AN145 what is it doing? If it is blinking slowly, then it has not been added…
Looking at what you did above, I see you working only on the Vera, but the process is a two step process.
To exclude devices: Press and hold the MiOS system’s Zwave button for 3 seconds and then release. The Zwave light will blink rapidly, 4 times per second, to indicate the MiOS system is in exclude mode.
In your original post this is what you said you did, and only this as I read what you wrote… I believe you wanted to tap the Zwave button once again at this point to get a slow blink. (you are then in include mode) at this point touch the button on the AN145 to add it to the Vera.
Hope that helps…
To include devices: Tap the MiOS system’s Zwave button. The Zwave light will blink slowly, once per second, to indicate the MiOS system is in include mode.
Carry the MiOS system around to all the devices you want to include or exclude and press each device’s activate button. When the MiOS system has successfully included or excluded a device the Zwave light will flutter for 2 seconds as confirmation.
When you have finished adding or removing devices and want to save your changes, tap the Zwave button once if include mode to exit include mode and go back to normal.
When the MiOS system has finished saving the new devices and resumed normal operation the Zwave light will come on solid again. If you’re in exclude mode and want to save your changes, tap the Zwave button once to go into include mode, then, when in include mode, tap it again. When the Zwave light is on solid you can now unplug the battery pack and reconnect the MiOS system like normal.
