Hi, I have two controllers (in different houses). I can get to the AltUI login page that shows the controllers but I can’t login & get this error message under a button that says “Toggle Details”:
This is not an error it is detailed info ( which you should remove from the post )
You should check the std getvera remote login page and try log in both controllers
Altui is not doing special things here
Thanks amg0, I removed the code from my post but it’s also showing in your response. I can login to either controller with no problems.
fixed
you can use my private message for info. what exactly is your problem can you show it on a screen shot ?
this text you showed is not a error message and not indicative of a problem. to login to a controller you need to click on the lines in the table. if it works from getvera remote control accesss, it is expected to work here. potential issues could be some special characters in names of controller…
Special character - that was it. Thanks!
