[solved] device:18 has duplicate state id
I deleted a couple of workflows from AltUI which I implemented in PLEG.
Now i get
15.8.2017, 12:15:36 warning device:18 has duplicate state id 61 for variables: RemoteVariablesToWatch , Wflow_0-19_2 ? 49 15.8.2017, 12:15:36 warning device:18 has duplicate state id 60 for variables: VariablesToSend , Wflow_0-31_0 ? 49 15.8.2017, 12:15:36 warning device:18 has duplicate state id 59 for variables: VariablesToWatch , Wflow_0-19_0 ? 49 15.8.2017, 12:15:36 warning device:18 has duplicate state id 58 for variables: GoogleLastError , Wflow_0-18_2 ? 49 15.8.2017, 12:15:36 warning device:18 has duplicate state id 57 for variables: VoiceRSS_KEY , Data_CustomPages_0 ? 49 15.8.2017, 12:15:36 warning device:18 has duplicate state id 56 for variables: LocalBootstrap , Wflow_0-18_1 ? 49 15.8.2017, 12:15:36 warning device:18 has duplicate state id 55 for variables: LocalCDN , Wflow_0-18_0 ? 49 15.8.2017, 12:15:36 warning device:18 has duplicate state id 54 for variables: ExtraController , Wflow_0-17_3 ? 49 15.8.2017, 12:15:36 warning device:18 has duplicate state id 53 for variables: BackgroundImg , Wflow_0-17_2 ? 49 15.8.2017, 12:15:36 warning device:18 has duplicate state id 52 for variables: ImagePath , Wflow_0-17_1 ? 49 15.8.2017, 12:15:36 warning device:18 has duplicate state id 51 for variables: ThemeCSS , Wflow_0-17_0
device 18 is AltUI.
workflows 19 and 31 have been deleted but show up in the warnings.
I tried debug > fix device states a couple of times, reloaded luup engine, didn’t help.
What can I do to fix the problem?
[quote=“pls90, post:1, topic:196971”]I deleted a couple of workflows from AltUI which I implemented in PLEG.
Now i get
device 18 is AltUI.
What can I do to fix the problem?[/quote]
debug > fix device states Is the only way
Enter 0-18 in the text box then wait until it reloads
That should do it
i did that a couple of times.
Why are workflows mentioned in the warnings although already deleted?
Variables remains in user data. Vera does not support variable delete.
so my only option to get rid of the warnings is to delete the workflows in question and build from scratch?
no that may not help. you basically have in your user_data several device variable associated to that device which have identical variable id. that can only be fixed by manually editing user_data json data structure ( complex & risky ) or by using the procedure that I indicated earlier. do not trigger the luup reload yourself, once you typed in te device id ( 0-18 ) let it go and observe the reload ( orange message button ) hapening by itself
amg, I did as you suggested many times over the past week.
Finally the warning have stopped. Thank you for your patience.
