Need help to setup the calendar.
I have followed the manual and finished the “Setting up a Google V3 API Service Account” (service account created).
The user rights for the new user is set in the online google calendar.
I have installed the app and am trying to configure the calendar.
I am using the standard name of the json file and have uploaded it to Vera.
I paste the ID:
Then Press “Set”
First it say: see attached file.
Later it say “** ** No more events today”
However, I have several meetings in the calendar for the current day?!
[quote=“paros, post:1, topic:198171”]Need help to setup the calendar.
I paste the ID:
Then Press “Set”
However, I have several meetings in the calendar for the current day?![/quote]
Tried with the testfiles from “Documentation” and getting error: see attached file 2
I am also having troubles setting this up on openluup.
For me it is working with the test credentials, but not with my own.
After a while I realized that the client_mail I added under “share with specific people” in the calendar settings just disappears.
When arming the device I always get “Http error code: 403” which hints that there are permission issues.
How do I make the client_mail “stick” under my calendar settings?
[quote=“pls90, post:3, topic:198171”]I am also having troubles setting this up on openluup.
How do I make the client_mail “stick” under my calendar settings?[/quote]
I understand what you mean.
Change back to “Classic mode”- here you only have “Share with specific people” - here the shared address is still saved.
In the “new” UI there is both “Access permissions” and “Share with specific people” - here the shared address is disappearing?
However, the calendar is empty for me?!
I created a new device from AltUI and it showing the same…
I tried again with the test file provided in the documentation and now I getting this error.
The file (GCal3Test.json) is already uploaded and I can see it under luup files.
Thank you for pointing out the different settings pages for new/old calendar layout.
Switching back to old design actually brought up the client_email address I had entered which was not showing in new design (still some kind of bug in new design?).
Regarding my error message (Http error code: 403) it didn’t make any difference though.
What looks fishy is the fact that I have set gc_debug to 3 but the log file (31-GCal3.log) has 0 bytes.
Is anyone running the plugin on openLuup successfully and willing to share their permissions that are set for the GCal files / directories? Thank you.
@jswim788, great, thank you! I did fumble with permissions a bit and got it working.
Alas, I quite don’t know which one it was that made the difference in the end.
Now I will have do a bit of reading how to put this to use
Along the way -(likely when google changed the UI last) – the service account instructions omitted the need to enable the Google Calendar API.
I have added it back in (as the first step). Thanks for pointing it out.
