When I choose one of my radio stations in the favorites list and press PLAY - nothing happens.
/Martin
/Martin
What kind of radio is it ? TuneIn ? Web radio ?
Same result whatever the radio ?
Sometimes, the radio is not available. Check if you have an error message in the Sonos control application when playiing your favorite radio. Check the Vera logs too in case there is something not normal.
[quote=“lolodomo, post:2, topic:178900”]What kind of radio is it ? TuneIn ? Web radio ?
Sometimes, the radio is not available. Check if you have an error message in the Sonos control application when playiing your favorite radio. Check the Vera logs too in case there is something not normal.[/quote]
Web radio; Strange thing. After I started it using the Sonos App (iOS - NOT on Vera), it started working on the Sonos plugin on Vera as well.
One request though : I am using PLEG extensively, and set it to start a certain radio station at a given time of day.
I didn’t find any “PlayFavoriteRadio” in the list - so I used “PlayURI” - and added the radio stations http-address. This works - however - would be nice if I could just choose from the list of favorites.
Brgds,
Martin
Open the Help tab, you will find an example in the table for favorite radio.
Just use FR:name as parameter for PlayURI.
[quote=“lolodomo, post:4, topic:178900”]Open the Help tab, you will find an example in the table for favorite radio.
Just use FR:name as parameter for PlayURI.[/quote]
Oh - nice ![]()
