[Solved] Aeon Labs Multisensor Reading In Celsius
I installed the US firmware, but it’s still reading Celsius. Vera is set to Fahrenheit and that’s what the dashboard weather temp is showing in.
Does anyone know if there is a detailed setting on this device that I can tweak to make it show Fahrenheit?
Edit - I changed the Vera settings from Fahrenheit to Celsius & back again & it worked.
Same problem here except even after toggling multiple times it is still in Celsius. My Nest, Wunderground and Everspring devices are all in Fahrenheit. 1.18 US firmware on the multi sensor.
