I have a VeraPlus on the way (Wed 2/17 delivery). I am coming from SmartThings. I am unsure what to expect as far as setup. More specifically the part about detaching from SmartThings. From what I have gathered Z-Wave devices have to be manually excluded first? Is that true? Or can I just add them to Vera also?
Here is what I am moving over:
GE / Jasco Z-Wave switches / dimmers / fan controls
Philips Hue hub and 10+ lights
Amazon Echos
Osram Lightify colored bulbs
Harmony Ultimate Home hub / remote
Chamberlain MyQ garage door
Ecobee3 thermostats & remote sensors
Nest Protect smoke/CO2 sensors
Lowes Iris contact sensors (the new CentraLite versions that work with ST and other Z-Wave hubs)
Fibaro Motion Sensors
SmartThings brand Z-Wave outlets
Rheem EcoNet Connect
I’m guessing some of these may not work. Or may not work without extended efforts. Any thoughts from the Vera experienced here? Again more specifically what I need to do prior to starting to add things to Vera. Thank you so much and I look forward to becoming Vera versed soon! ![]()
