I’m running firmware version 1.0.979 and when I install the smartphone web interface plugin, it does not reload successfully and shows the following messagens after entering the main page:
Version: 1.0.979
Checking internet connection …
Loading timezones.json …
Loading local database …
Loading sysinfo …
timezones.json loaded
Internet check status: ok
sysinfo.json loaded
Communication error while retrieving local database.
And the only way to get back from that is to restore to factory default with the reset button.
I’ve tried that several times, cleared all browser cache and the problem still happens.
Did that happen to anyone else? I couldn’t find anything on the forum regarding this subject.
Well, it does not reset to a prior state, it will clean up to factory default. There is a small black reset button at the back of the unit next to the antenna and you just press it twice quickly. The power led will turn off and turn on again in a while. It will be up and running again and you would have to configure everything back again (unless you had a configuration backup to restore).
Got it. But I find that whenever I load the Smartphone plugin, the same problem occurs. I then have to do the reset and reload from a backup that did not have the plugin installed.
Bottom line, what’s up with this plugin? I’m using 1.0.979
The problem I’m having is that whenever I ‘install’ the Smartphone Web plugin on Vera, I can no longer access Vera. Not locally, not remotely, not via the iPhone. Vera seems to hang, continues to repeat ‘Vera busy, retrying…’ and then times out. If I then do a reset and reload a backup (that does not have the Smartphone Web plugin installed) all is well again.
Something funky with the plugin me thinks. Yet others seem to be using it just fine. I’ve sent several message to MiCasaVerde support but no response yet.
Would the new beta firmware have addressed this issue? I’m using the new firmware but am hesitant to try the plugin again unless you believe this problem has been addressed there. Any insight is appreciated! Thanks.
