Is it possible to use my Trane thermostat temperature reading as the sensor for the “Smart Virtual Thermostat” plugin? I tried using the Trane ID as the temperature sensor setting, but it did not seem to work.
Did you get an answer to this? I just came across this plugin and was wondering the same thing.
Not really – I know the plugin has evolved since I looked at it (so the problem might be solved), but it turns out cheaper for me to just buy another ZWave thermostat and hook it into my wall mounted electric heater via a relay than it would be to kludge something with the Virtual Thermostat plugin.
