Sometimes I get weird / slow zwave behaviour on my hub. Tonight, this leads to a lack of control of my blinds.
After resetting the hub (which sometimes helps), things do not improve today. In the zwave log, I get the following messages, starting at the moment when I try to set the blind (MLSwitch).
Is there any clue in this log what’s wrong with the network? The errors and warnings are a bit vague, though they seem to point to issues with node 12, 26 and 27.
2022-11-11 19:55:59.051132 INFO : set MLSwitch: value(82)
2022-11-11 19:55:59.074341 INFO : znetNodeCmdBinarySwitch (node id: 12 channel id: 0) value: 255, target value: 0, duration: 0
2022-11-11 19:55:59.074668 INFO : Cant handle node 12, use monitoring handler instead
2022-11-11 19:56:00.431163 INFO : znetNodeCmdBinarySwitch (node id: 26 channel id: 0) value: 255, target value: 0, duration: 0
2022-11-11 19:56:00.431497 INFO : Cant handle node 26, use monitoring handler instead
2022-11-11 19:56:01.838167 INFO : znetNodeCmdBinarySwitch (node id: 27 channel id: 0) value: 255, target value: 0, duration: 0
2022-11-11 19:56:01.838506 INFO : Cant handle node 27, use monitoring handler instead
2022-11-11 19:56:04.354623 ERROR: CurrentValuesHandler, Failed cc processing. CC = 142, ch = 2, fail = 2
2022-11-11 19:56:13.684333 INFO : znetNodeCmdBinarySwitch (node id: 12 channel id: 0) value: 255, target value: 0, duration: 0
2022-11-11 19:56:13.684684 INFO : Cant handle node 12, use monitoring handler instead
2022-11-11 19:56:15.043086 INFO : znetNodeCmdBinarySwitch (node id: 26 channel id: 0) value: 255, target value: 0, duration: 0
2022-11-11 19:56:15.043491 INFO : Cant handle node 26, use monitoring handler instead
2022-11-11 19:56:16.451741 INFO : znetNodeCmdBinarySwitch (node id: 27 channel id: 0) value: 255, target value: 0, duration: 0
2022-11-11 19:56:16.451978 INFO : Cant handle node 27, use monitoring handler instead
2022-11-11 19:56:17.009830 INFO : znetNodeCmdBinarySwitch (node id: 29 channel id: 2) value: 255, target value: 254, duration: 0
2022-11-11 19:56:19.274959 INFO : znetNodeCmdMeter (node id: 29, channel id: 2, type: 1, scale: 0, value: 0)
2022-11-11 19:56:20.631822 INFO : znetNodeCmdBinarySwitch (node id: 12 channel id: 0) value: 255, target value: 0, duration: 0
2022-11-11 19:56:20.632351 INFO : Cant handle node 12, use monitoring handler instead
2022-11-11 19:56:21.989705 INFO : znetNodeCmdBinarySwitch (node id: 26 channel id: 0) value: 255, target value: 0, duration: 0
2022-11-11 19:56:21.989996 INFO : Cant handle node 26, use monitoring handler instead
2022-11-11 19:56:23.347429 INFO : znetNodeCmdBinarySwitch (node id: 27 channel id: 0) value: 255, target value: 0, duration: 0
2022-11-11 19:56:23.347798 INFO : Cant handle node 27, use monitoring handler instead
2022-11-11 19:56:23.956270 INFO : znetNodeCmdMeter (node id: 29, channel id: 2, type: 1, scale: 2, value: 0)
2022-11-11 19:56:23.956601 INFO : Cant handle node 29, use monitoring handler instead
2022-11-11 19:56:32.839581 ERROR: AssociationRequest fail (continued). Error=-7, args=[31, 0, 1]
2022-11-11 19:56:32.890502 INFO : znetAssociationResult (node id: 31, group id: 1)
2022-11-11 19:56:34.205495 INFO : znetNodeCmdBinarySwitch (node id: 12 channel id: 0) value: 255, target value: 0, duration: 0
2022-11-11 19:56:34.205865 INFO : Cant handle node 12, use monitoring handler instead
