I have a scene that turns on a light for 3 minutes if motion is detected. Works fine
However if I turn on the light manually so it will stay on, the scene still runs and turns out this light in 3 minutes. What can I add to this scene to …
sense the light is manually operated, so do not turn off lights
If the light is manually turned on, only turn off if no motion is detected for , say, 15 minutes.
