Is there a way to show the Enable and Disable button for Reactor sensors in the Vera Mobile App? In the app, you only get the Reactor symbol and there is no way to Enable/Disable, Arm/Disarm or Trip/Reset. Is it possible to change the device_file, device_json, category_num and subcategory_num in the Advanced Tab to acheive this? I have done this with Virtual Switches before, however never with a sensor.
