I have been running alpha 5 version of the plugin with my RFXrec433 v46, all is well under Vera Lite’s UI5 firmware 1.5.346. I never upgraded my UI5 because I heard the RFXtrx plugin has compatibility issues with the newer .408 firmware. Is this still true?
I was on the board next door to find out an error with installing the datamine plugin and was suggested to upgrade the Vera firmware to .408. So my question is:
If I upgrade Vera to 1.5.408, while keeping alpha 5 and v46, will there be any problem?
If yes, which plugin version should I upgrade to? Alpha 10 or beta 1?
Do I need to upgrade the RFXrec433 firmware?
Thanks very much.
