I need to unpair a Shlage BE469NX and have been able to find the proper procedure. I would appreciate it greatly if someone could please advise.
No need to respond, I’ve figured it out.
hi
First I paired it but cannot change the user code. Finally I updated my Vera Edge controller to 1.7.2607 and now i can change the user code but only with default lenght that is 4 numbers . when i changed it diectly on my Schlage loock that’s stop working on my vera dashboard.
Someone can help or had the same issue.
Tks
See this post. You may find others with Google searching: http://forum.micasaverde.com/index.php?topic=36447.0
Can you provide some instructions please? I’m having the same problems. Thanks Much
