Hello,
so I already had my system with ~50 devices set up using OpenHAB (I am coming from the other way around) using Aeon Z-Stick2.
I bought an Vera Edge for the reason many of you are listing here, to have something dedicated and stable to control Z-Wave as well as to have an emergency gateway for when OpenHAB is going amok.
I have managed to include the Vera Edge into my Z-Wave network, but I am unable to shift the primary controller (through the Vera Edge interface Settings>Z-Wave>Advanced>Controller Shift) to the Vera Edge. It is now a secondary controller.
All I get is the following message:
Command failed: There appears to be a problem because this controller is not set as the primary controller for the system. (It may be under the control of another controller.)
which is logical. Clearly I need to initiate the shift from OpenHAB/Aeon Z-Stick2.
How would you go about doing this?
I am very keen about not having to go about excluding/including every device again…
