Is it possible to add a timeout to move back to the home dashboard set?
I have a main dashboard with 6 large icons for example lights etc. When selecting lights and doing whatever i need to do I want to walk away and then after a set time have the dashboard change back to the home dashboard.
I tell the Imperihome add on in a scene every 30 minutes to go to the home page. Works well enough that I see the home page when I walk by most of the time (probably 99% of the time) and is pretty easy to set up.
While you are messing with it you may want to tell it to go to your security page when a security sensor it tripped or maybe the weather page when a weather even occurs. it is a nice feature.
