Shelly temperature and humidity sensor
I got myself one Shelly H&T humidity and temperature sensor. It uses wifi and operation principle is that it is mostly sleeping but wakes up when readings change or timeout happens and then sends values to Shelly system.
It is possible to set additional “action url” to which device sends values, sending happens always with query format
?hum=XX&temp=YY&id=shellyht-ABCDE
To my knowledge it is not possible to modify this format.
Is there any plugin or other way in Vera to receive values in this format? If not, is it even in theory possible to make a plugin to receive this format?
I think you could probably do this with the Virtual Site Sensor. If you use the Alternative User Interface (AltUI) you can install the Virtual Site Sensor from there. Note I’ve not tried this. The Shellies can shoot off any URL you like and that could be used to update Virtual Sensors.
