sharp tv ip help please
need help please… 2 issues
using vera edge ui7 installed thesharp tv app. put the ip nothing happens . am i missing a step what am i doing wrong help pllease thanks.
  1. sonos. installed the app works on the dashboard but on my vera mobile app its grayed out cant do anything all i have is an on off button that does nothig
Im having the same problem with mine
Hi
Any one had any luck with this?
i also have the same issue - Sharp app does not work ( UI7)
Here is some link which has some files attached and need to be used. it creates the device and simulates the device.
[ftp=ftp://forum.micasaverde.com/index.php?action=post;quote=72226;topic=10365.15]http://forum.micasaverde.com/index.php?action=post;quote=72226;topic=10365.15[/ftp]
[quote=“oren45, post:3, topic:187387”]Hi
Thanks[/quote]
I’m having the same problem on the vera lite 1.7.690. The buttons don’t light up green for the selected but I can click and get the tv to turn on and off.
Scenes are even worse since I can’t select the controls for them on there. It seems to be a vera thing more than the plug in because the yamaha plugin is giving me the same issues but not as bad.
To update anyone who finds this in the future I ended up calling Sharp technical support and they helped me activate the “Aquos Remote Control” This allowed for IP control and I was able to continue setting up the plugin from there!
I tried the Sharp app on VeraEdge, does not work. I’m familiar with enabling the TV.
Have you sent the “OnIP” command with an advanced scene? I think you need to do this while the TV is on so that it is always listening to IP control. You can also test with the Aquos phone app to use as a control for your experiment.
Thanks, Sharp TV is setup correctly; I already use it with other IP controller.
