Hi all,
the new flat will have all the shades electric; this is standard, not my choice.
I will have switches on the wall to move them up&down.
Is it enough to buy a simple 2x1.5kW Fibaro switch?
Marco
Hi all,
Marco
The module you mention is not suitable for motors (risk of turning on both directions at the same time)
you need an AC Z-Wave motor controller, there are several manufacturers to choose from
info@zwavemotors.com
[quote=“MarcoGT, post:1, topic:181732”]Hi all,
Marco[/quote]
I use a Fibaro fgrm-222 in two windows with good results.
use the fibaro roller shutter 2 module or equivalent, the double relay is to switch 2 loads independently.
contact us for more details: info@zwavemotors.com
