Setup problem: Internet Connetion Error!
I have a VeraLite from eBay and I’m having problems setting it up. I’ve gone through the home.getvera.com process up to step 3, but on step 3, I get a giant red banner saying “Internet Connetion Error!” (note the lack of ‘c’) while the upper right corner indicates that “Updating control software…” is ongoing. Every few seconds, the red banner switches to a blue “Loading…” message and then switches back to the red banner (a refresh attempt I assume). As you can tell from this post, my internet works fine. I have had no outages while attempting this process. My VeraLite is hardwired to the wireless router that is hardwired to my cable modem.
When I go back to the root page on home.getvera.com, I am unable to log in using the information I provided so I assume that information only gets saved on the server when this process completes. When I click the “I have a new controller” button again and agree to the terms and conditions again, I am advised “Setup Wizard Already Started” and the serial number indicated on the page matches my device. When I click “Continue Setup Wizard”, I had previously (the first two times I tried this process) been asked to re-enter the two pages of information required by Vera. Now, clicking “Continue Setup Wizard” leads me directly to the “Internet Connetion Error!”
I’ve called Vera support twice during business hours and gotten an answering machine. I’ve emailed and received no response. Any tips on how I can get my VeraLite to be anything but a paperweight?
I’ve checked on our ticketing system and as far as I can see you’re already in touch with one of our agents. Be sure to follow-up with us so we can resolve your issue asap.
Hello, I bought a Veralite two years ago and have always used UI5. Yesterday I upgraded to UI7 and now I have the same identical problems by bjp. I can connect within the LAN using the IP address.
What can I do?
Thanks,
Angelo
Hello,
as i have the same problem “Internet Connetion Error!” i posted here, no matter where i try to add my controller to my account, it says “Internet Connetion Error!”
How can this be solved, cant acces UI when im away.
Localy everything seems to work. Except those features that need account to be logged in.
Vera Lite G
Running version: 1.7.739
Thanks.
I am trying the same operation once again; now the error after step 3 is the following:
Something went wrong!
There was an error on our side. Please click the retry button to try again…
And once clicked, the error just shows up again and again and again…
:frowning: >:(
After been contacted by the customer care via email, I solved the problem by registering using the website http://legacy.getvera.com/
Cheers
