Can anyone please provide easy to follow steps of transferring the configuration in box.net into beta so I can use the SQ Blaster from Vera’s mobile app. I have Vera 3 and UI5 , the plugin is already installed and link to my Blaster just don’t know what to do next to extract the already configured information in box.net.
From what I can remember you cant. Some people in the past talked about a method if you had a jailbroken ios device. The problem started when box net changed their API and Square Connect seemed to abandon the product.
From what i was told from MIOS Support is that it can be done by taking the configuration from box.net and transferring it to Vera. I just can not find a clear understanding of how to link Vera to the existing configuration which is currently operation all my IR devices thru SQ Blaster. The MIOS Support person I talked to said he was new with no prior experience working with the blaster.
The iPhone app saves a set of configuration files to box.net… or at least it used to.
The Blaster plugin, along with the XSLT transformation files, morphed this information into a form that could be loaded into Vera… and would work with the binding.
Without those original files you’re kinda stuck, since the definition of how to talk to a device, like a specific Amp model, are contained in the iPhone and/or box.net data.
The files are in box.net and i can get to them just don’t no what to do next to merge it all together, please tell me step by step if you would please.
If you have the .xsl transformation files, as well as the SQBlaster devXXXXXXXX.xml files from box.net, then you can follow the instructions at:
http://code.mios.com/trac/mios_sqblaster
They’re the high level steps, with links to the Forum postings with the step-by-step versions.
You’ll need to adjust for UI7, as I’ve only tried it under UI4/UI5.
I am currently running UI5. I don’t know how to get the .xsl transformation files and I don’t know what to do with the xml files on box.net can you please provide a clearer step by step way.
The transform files are attached to one of the other threads you inquired on:
http://forum.micasaverde.com/index.php/topic,29848.msg211580.html#msg211580
You now have all the detailed info you need in order to get going.
sendir,1:1,1,37825,1,1,343,172,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,63,22,63,22,63,22,63,22,63,22,63,22,63,22,63,22,22,22,22,22,63,22,63,22,22,22,22,22,22,22,22,22,63,22,63,22,22,22,22,22,63,22,63,22,63,22,63,22,1509,343,85,22,3700
sendir,1:1,1,37825,1,1,343,172,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,22,63,22,63,22,63,22,63,22,63,22,63,22,63,22,63,22,22,22,63,22,63,22,63,22,63,22,22,22,63,22,22,22,63,22,22,22,22,22,22,22,22,22,63,22,22,22,63,22,1509,343,85,22,3700
