I’m passing this info along for others who are encountering issues setting up their new vera box. This cost me a couple of hours attempting to figure out what was wrong.
Background: I’m a new user having just purchased vera3
Problem: I had trouble using the web interface to the vera3 on a 64 bit Windows 7 machine and running IE 9.
The Fix: Switching to Firefox has fixed the issues I encountered.
Details:
IE 9 appeared to work fine for most pages, but there was some flakiness and in some cases I was not able to do a task at all. The major issues were:
Not being able to change the room for scenes
Not being able to select the day of the week radio button on the Add Schedule page for a scene
Not being able to add a non-supported generic IP camera even
I had tried running IE 9 in compatibilty mode but vera detected this and displayed a dialog requesting that I upgrade to one of the latest browsers.
If you are having issues during setup, I recommend verifying that you are using FireFox as IE 9 doesn’t appear to be supported.
I ran into a similiar issue this past wekend trying to setup a generic camera. This was using IE 9 on windows 7 and also Safari on my iphone.
I cant say yeah or neigh to the other items on your list that you found.
I’m running the Vera Lite and noticed some weird things under IE9
When I install an App, e.g W.O.L it will open up the settings box and no matter what I do to code it (clicking on the X top right) it springs back up again, i can’t make it go away, so in the end I have to remove the app.
Apart from necessities in some case where people don’t get a choice due to work IT policies etc, I can’t see why anyone would still want to use it when Chrome kicks butt!
