setting up vera
Can I set Vera and my schlage lock up in New jersey and then bring Vera and my lock down to Florida and put in my Vacation Rental or do I have to set it all up again. I have Comcast modems in both houses. Thanks MIke
Assuming your Vera will be within communicating distance to the locks when in FL, you should be fine. If you are using lamp modules/switches/etc, then the routes between devices will need to be relearned once they are in place in FL.
You will need to ensure that your Vera connects out to the internet correctly when you are in Florida as well.
D.
Ok Thanks, I’m only using is the lock it’s a small condo maybe 20 feet away from the modem.
