Setting up NTP time sync with Vera and a Windows server Time service
My Vera is internal only (no internet access, prevented by Firewall). Anytime I disconnect Vera (say to pair with a z-wave device), I lose the time/date (since it can’t connect to get time from the internet).
So - I followed the steps in the wiki here: http://wiki.micasaverde.com/index.php/Time_Syncronization
After that, I edited /etc/config/ntpclient to add my Domain Controller (Windows Server 2008R2 that’s running a Time Service).
Starting the client failed - because of a lack of trust between the two machines.
The NTP client has a -t option switch that lets you “trust” the connection (not really recommended, from what I understand). After much digging, I found that if I edit the file: /etc/hotplug.d/iface/20-ntpclient
and put a -t option on the two command lines, the start works fine.
Putting this here - in case anyone else with an internal only Vera has the same issue/setup.
EDIT:
FAIL that didn’t work.
So i guess this turns into a question… how the heck can I get Vera to get NTP from a windows domain controller?
Update - my initial post still stands - the update did work, and the NTP daemon is running.
the -t option, when specified in the 20-ntpclient file does the trick.
 2205 root      1068 S    /usr/sbin/ntpclient -t -i 600 -s -l -D -p 123 -h 192.168.1.9
 3329 root      1676 S    rdate -s ntp.xs4all.nl
 3339 root      1672 S    grep ntp
I’d love to get that rdate to stop all together - it seems to only run for a short period, so not horrible to keep.
