ok so I have everything working in the main house, and the thermostat, motion, lamp, and door are working in the guest house (off the main controller from the other house). I am running cat6 from one house to the other next trip, and would like to set up the guest house independently so the renters can control. This would be a second Vera on the same network, or using the guest network. Is there a way I can do this and still maintain visibility of the settings from my initial system? Don’t want to give them access to my stuff, but would like to still access as necessary. Thoughts?
Thanks in advance
