Setting the timezone
I cant find any city in Israel.
Is there alternative option for setting the timezone in Israel ?
[quote=“inmar32, post:1, topic:180420”]I cant find any city in Israel.
Thanks[/quote]
The city is not important but set the Latitude and Longitude to match your location. Google can help you find these for your nearest city.
The best you can do is to to pick a nearby city, say, Istanbul or Beirut or Damascus, which is in the UTC+2 area. Unfortunately no other jurisdiction seems to have exactly the same daylight saving start and end dates as Israel. So you may find that the time is an hour out for a day or two in March and October.
I suggest you raise a support request to have a city in Israel added to the list.
Exactly the issue I am facing right now.
In Israel we moved to summer time and now I need to define my micasaverde to Bagdad…
Where do I raise support request ?
You can submit via you Vera or
http://support.getvera.com/customer/widget/emails/new?
I can see in UI5 there is also Hebron and Gaza
Hebron and Gaza it’s not realy Israel…
Yes, but the timezone is the same.
