tdubbs
December 14, 2014, 5:36pm
#1
Hi Guys,
How do you set the priority and sound in a veraAlert that uses pushover?
luup.call_action(“urn:richardgreen:serviceId:VeraAlert1”, “SendAlert”, {Message = “Door open {tone:1}”, Recipients = “”}, 21)
… I just receive a message with {tone:1} in the message.
I cant seem to search the right thing to find the answer. Thanks!
{tone:1} is the syntax for the Vera Alerts Mobil app.
There is some help info on the bottom of the PushOver profile editor in the Vera Alerts Plugin.
[quote=“tdubbs, post:1, topic:184710”]Hi Guys,
I cant seem to search the right thing to find the answer. Thanks![/quote]
I’ve found how to call for specific sounds while reading the API documentation on the pushover website.
[url=https://pushover.net/api#sounds]Pushover: API
I’m using VeraAlerts to send pushover notifications to iOS or Android similar to the example below (posted from a PLEG status report, so syntax may vary)
Message={device=GalaxyS4}{sound=bike}Left Home Recipients=Pushover-DebFace
There are priority settings in the API page linked above (I don’t use priorities, so I’ve never tested)
Hope this helps
Chris
delbz
December 14, 2015, 5:05am
#4
Her’s the code for sound that works for me.
luup.call_action("urn:richardgreen:serviceId:VeraAlert1", "SendAlert", {Message = "Door opened at {DateTime(CurrentTime,%H:%M on %A %B %d, %Y)}{sound=spacelarm}", Recipients = "Pushover"}, 16)
