Set Start / End time of a schedule using a Multistring VC value?
I would like to be able to vary my schedules start / end time by adjusting a variable? Is this possible?
John
I have not used PLEG in a while. When I did, I had PLEG place data into multistring VC so you should be able to get PLEG to read a variable from multistring VC. If I recall, I had to play with it to figure out the structure to get it to work.
Thanks for the reply… I can use VC in pleg, I do so for temperature set points… im just not sure how to get it working for start/end time field.
John
