Hmmm… When I try to login using vera mobile over cell phone network it says failed to connect. Even thought the internet connection works and remote viewing my ip cameras in a different app works. When I turn on WIFI and connect to the same LAN it works.
When I try to login to cp.mios.com outside the network it says unable to connect with unit… any ideas?
It’s a rare issue that somewhat frequently comes up here. Meaning that many people come here when they experience this issue. But, the issue itself very rarely occurs. It seems to happen to some few people more frequently and to most people it almost never happens.
My suspicion is that those that suffer the problem more frequently have an issue with their ISP or router. Most Veras work “perfectly” for months/years.
I would recommend against scheduled resets, but your specific circumstances may require such extreme measures. Since I have zero information about your circumstances, I can’t advise you specifically.
argggg did it again obviously its an issue on my end. i am still recieving my vera alerts but pictures are not coming through. still getting connection failed from vera.
my external ip is the same because my third party ip cameras are still working
anyone have any ideas what can be causing this? running low on memory? anybody have any ideas?
Try power cycling your Vera (Reload from Vera Control Panel is NOT the same).
If that recovers it … it is likely that your router or your ISP is dropping the connection.
I would recommend that you have a Static IP for Vera.
It might be that your Router and Vera are not handling the lease termination properly.
This will require changes on your router to return a fixed IP everytime Vera asks for one.
I do NOT recommend any form of Port forwarding … other than SSH.
Happening again… Just added two new switches. Put back on power and network… the network light flashes green rapidly. I can connect locally but not remotely I tried:
Removing DHCP reservation
Making vera dmz host
turning off parental controls
My router indicates that vera device is connected and I can ping it
Any ideas? This time the powercycle is not even fixing it. I have power cycled the router and vera several times.
setting the static ip in the router works better most of the time. vera should not have 192.168.1.1 as this is routers ip and dns should be 192.168.1.1
