I currently have 8 outside light fixtures that are on the same cct and same switch. I want only the front four to be on most of the time and not the side 4. Anyone know how i could control the side and front ones separately. I currently have a vera lite. Any electrical re-wiring would be a big job at this point so i want to avoid it. Any help would be greatly appreciated.
With out being able to re-wire the lights, are you very limited on what you can do. The only option I can think of is install wifi bulbs in each light (look at MiLight / Limitless LED).
- Garrett
Depending on your fixture style, there’s also the HA05 screw-in lamp module (example [url=http://www.ebay.com/itm/HA05-Z-wave-Intermatic-Outdoor-Screw-In-Lamp-Module-Zwave-/151173691638?pt=Home_Automation_Modules&hash=item2332a778f6]http://www.ebay.com/itm/HA05-Z-wave-Intermatic-Outdoor-Screw-In-Lamp-Module-Zwave-/151173691638?pt=Home_Automation_Modules&hash=item2332a778f6[/url]). Seems like it might be cheaper to hire an electrician to run new wiring.
Thanks guys
I have a similar situation with some outdoor floods. I want to install cameras at the same locations but the circuits are controlled from switches in the house — in this case Z-Wave switches but still they are on or off so there is no practical way to put cameras at the flood light locations without new wiring.
So I’m thinking about this:
- Remove the current GE Z-wave switch in the house
- Replace with a standard on/off manual switch (to allow override control of the AC for maintenance purposes)
- Remove the flood light fixture
- Install a large waterproof plastic electrical box over the current box
- Pull the AC wiring into the box
- Install a Aeon Labs DSC26103 Z-wave switch in the box wired across the incoming AC
- Install a new Flood fixture on the eaves wired to the Load side of the Aeon Labs device
- Install a standard duplex AC outlet inside the box across the incoming AC line. Most low cost camera AC supplies are plug in types so they need a standard outlet but it wants to be protected inside the box.
This results in full time AC to the box, camera and Z-wave switch and still allows Z-wave control of the outdoor lights
I’ve identified the right Aeon Labs device and an outdoor box large enough to install it in and have plenty of room for duplex outlet and the camera AC supply. So now its just a matter of buying one set of parts to build a proof-of-concept model — and finding time to do it ![]()
