Hi there,
I’m using reactor to control a RS485 bathtub controller. I’m using this code in the RunLua:
local enter = string.char(0x0d, 0x0a);
local commandtosend = “HIDRO1:1;HIDRO1:1;” … enter;
local socket = require(“socket”);
local ADDRESS = “192.168.0.251”
local PORT = “23”
c = assert(socket.connect(ADDRESS, PORT))
c:settimeout(2)
print("Sending Command:: " … commandtosend)
local sres, serr = c:send(commandtosend)
local data, rerr = c:receive(5)
c:close()
It’s working OK so far. But…
If i send HIDRO1:?; as the command, it would return me 0 or 1 reporting if it’s off or on. Is there a way to query this value from the controller and, using the feedback, update the sensor status?
